Transmission Line
Old Nov 19, 2015 | 03:51 PM
KidRock'n's Avatar
Default Transmission Line
Hi guys,
Have a leaky driver's side transmission line from the transmission to the radiator on my 99 VDP. I was just wondering if anyone could tell me if this is the pressure hose or return hose so that I can order a new one.
Have had it fixed 4 times now and it keeps springing a leak. Getting a little sick of being the little Dutch boy with his finger in the dyke. As always, input is appreciated.
Best,
David
Old Nov 19, 2015 | 04:54 PM
avern1's Avatar
The drivers side is the pressure side, the passenger side is the return from the cooler.
Attached is a shot of the transmission and lines.
If you keep having problems with the coolant line it is time to take a look at your motor mounts or transmission mount. Something is moving causing it to leak. That's assuming they were installed correctly and the mating surfaces are not damaged.
File Type: doc
Old Nov 19, 2015 | 05:02 PM
KidRock'n's Avatar
That was about the most helpful post of all time! 11/10! Thanks man!
CBY335
Mar 9, 2021 09:57 AM
King Charles
Apr 14, 2017 05:28 PM
pab
XF (X260)
Nov 14, 2015 04:09 PM
64vette
Nov 13, 2015 07:57 PM
XJeej
Nov 13, 2015 11:06 AM
