Transmission Problem?
Old Apr 13, 2008 | 05:48 PM
FactoryJaguarTech's Avatar
Default RE: Transmission Problem?
That fact that it doesn't act up until it is warm would indicate more that it is something mechanical versus electrical. The hour is allowing the fluid to heat up and then it causes a problem. Due you get any warning lights? When it acts up, does it start right back up? When you have lack of power, does it have power again when you cycle the ignition?
Are you in Miami? I am in So. FL, but not Miami....a little further North...about 40 miles.
Old Apr 13, 2008 | 08:44 PM
I do not have a shop.
I would lime to know what code is in the TCM if that light is coming on.
Old Apr 14, 2008 | 05:09 AM
Yes I understand the trans light comes on. It needs to be scanned for the code.
RoyLittle0
May 25, 2023 02:38 AM
jdzubas
Oct 4, 2015 09:14 AM
XJsc-guy
Sep 25, 2015 11:09 AM
laserguy
Sep 3, 2015 02:02 PM
SouthernGypsy
Sep 3, 2015 10:54 AM
