transmission woe's
Old Jan 16, 2017 | 07:45 AM
jrb53's Avatar
Default transmission woe's
2002 xj8 120400 miles just changed the transmission fluid and filter. I drained fluid which was black so changed filter refilled then ran for 200 miles . decided to remove filter again and remove valve body cleaned everything put all back with new filter refilled with Pentosin ATF 1 now problem when I first put it in drive to go, it slips for the first 2-to 300 yards then it shifts great took on freeway no problems only dose it on cold start what did I do wrong.??? I never had a problem with the transmission before with the dirty fluid. any Idea what I did wrong thanks jrb53
Old Jan 16, 2017 | 08:57 AM
RJ237's Avatar
Maybe the Pentosin doesn't work the same?
Old Jan 16, 2017 | 09:32 AM
motorcarman's Avatar
The Pentosin ATF 1 is the correct fluid. I use it in WV/Audi 01M and 01V as well as the ZF 5HP24.
Maybe the valve body was reassembled incorrectly and/or leaking somewhere???
bob
Old Jan 17, 2017 | 07:21 AM
jrb53's Avatar
Thanks Motorcarman I was thinking the same thing. just dreading getting under car again. will post when I have it done
Old Jan 17, 2017 | 11:39 AM
Stu 1986's Avatar
Best of Luck, did you fit the modified valve in the gearbox?
Old Jan 18, 2017 | 07:37 AM
jrb53's Avatar
Hi Stu no did not change anything. What modified valve are you talking about. is this something I need to do ???? never had any problems with tranny before changing fluid
Old Jan 18, 2017 | 08:35 AM
RJ237's Avatar
http://jagrepair.com/images/AutoRepa...%20ZF5HP24.pdf
Old Jan 18, 2017 | 09:03 AM
BobRoy's Avatar
This is the updated valve I use.
TransGo ZF 5HP-24
Old Jan 19, 2017 | 07:31 AM
jrb53's Avatar
thanks ordering updated valve today will post when job is completed . thank you all for your imput
Old Jan 20, 2017 | 10:46 AM
Stu 1986's Avatar
I've got the Transgo valve ready to go in my car, it really is a recommended thing to do to preserve you from heartache later on. Best of Luck to you.
Old Jan 21, 2017 | 09:03 AM
jrb53's Avatar
Waiting for Fedx to bring the valve should have job done tomorrow will post with result thanks
