Trunk light out!
Old Aug 29, 2010 | 09:27 AM
joolz's Avatar
Default Trunk light out!
Just had my first oil change, the car is running flawlessly.
But, the trunk light is out. It worked fine before the change, and I am wondering is a switch got toggled or a connection got unplugged...
Where can I start checking connections? I don't know my way around cars much but am willing to poke (gently) around...
Joolz
Old Aug 29, 2010 | 01:08 PM
Stu 1986's Avatar
Check the wiring that runs along the RH boot hinge, that is a common area for wires to snap. I had this problem, and I solved it by making the wires slightly longer when I put a repair piece in, then wraped the wires in a length of narrow rubber hose to protect them if they got caught in anything.
It is very unlikely that the oil change will have had anything to do with your boot (trunk) lights. S.
Old Aug 29, 2010 | 04:41 PM
joolz's Avatar
Well, you never know!
Thanks I'll check, the boot is the rear, correct? (kidding!
Joolz
mbergen
Oct 23, 2019 10:26 PM
martybmw
Apr 2, 2016 04:55 AM
XJsc-guy
Nov 23, 2015 01:56 PM
prettydaim
Sep 7, 2015 05:16 PM
02jagstype
Sep 4, 2015 08:20 PM
