Trunk Only Pops When Open
Old Nov 7, 2009 | 02:47 PM
d3mje's Avatar
It'll be a chafed wire in the harness running to the trunk lid. You'll find the harness on the right hand (looking forwards) trunklid hinge. I't's partly covered by a semi rigid plastic sheath to protect it but this does fail eventually. Remove the loom tape, find the broken wire(s), solder them back together then re-tape the harness, repairing/replacing the plastic sheath as necessary.
You'll probably find that the broken wire(s) are touching when the trunk lid is open, but then part company when the lid is shut rendering the release buttons useless.
Mine went a couple of years ago and I noticed that the trunk lights came on when the trunk began to open then went off when it was opened fully. This eventually blew a fuse and I couldn't get the car out of park! (same fuse). Since that repair, I had a problem when the trunk would open from the remote or from the dash release, but not from the trunk lid button itself! Have now repaired and improved the harness protection so am hoping for a lasting trouble free period!!
BadKat174
May 26, 2023 12:29 AM
Aus V8S
Nov 13, 2015 11:01 AM
Chuck Schexnayder
Sep 18, 2015 03:10 PM
findre
Sep 10, 2015 05:46 PM
speacock
Sep 10, 2015 12:14 AM
