upper chain tensioners
Old Feb 12, 2013 | 08:52 PM
jamies xj8l's Avatar
Default upper chain tensioners
for good measure im going to change my upper timing tensioners. What kit do i need to put the aluminum newer ones in with the different bolts?
Old Feb 12, 2013 | 10:04 PM
coastaljag98's Avatar
If you order them from motorcars ltd they come with the new correct bolts. Do the zip tie method.
Old Feb 12, 2013 | 10:10 PM
What should i expect to pay?
Old Feb 12, 2013 | 11:04 PM
Tirefriar's Avatar
Here are the part numbers for the tensioners:
2W9Z6K254BA
2W9Z6K254CA
and the bolts (you will need 4): W500301S300
Call your local Ford part supplier and give them the above part numbers. They are the same as Jaguar but for much less.Don't forget the bolts, as the metal tensioners require shorter bolt.
Also, get the valve cover gaskets. Some recommend aftermarket, but I'd go OEM as its something that you will not replace often (we all hope).
Check this forum for "zip tie method". You will find pics and helpful recommendations. Good luck.
mikiep
Dec 20, 2019 07:37 PM
Jässe in Pälkäne
Oct 2, 2015 05:38 AM
millertic
Sep 30, 2015 08:11 PM
JAMES1944
Sep 29, 2015 11:58 AM
