Urethane shock bushings
Old Apr 9, 2020 | 06:59 PM
oteymus's Avatar
Default Urethane shock bushings
Hey,
2000 VDP front end clunk turned out to be lower shock bushings disintegrated. I believe the shocks are still good so I want to find some urethane replacement bushings. Any ideas?
Old Apr 9, 2020 | 07:49 PM
Highhorse's Avatar
These folks don't do the shocks, but the control arms... https://www.powerflexusa.com/shop/ca...1997-2003-1985
But these guys do... https://www.carid.com/2000-jaguar-xj...ings-hardware/
Have you replaced your upper tower bushings? Because if your lower are toast, most evidently your tops are also.
Old Apr 11, 2020 | 10:56 AM
nilanium's Avatar
The rubber lower bushings are cheap and last a while.. Second the upper bushings check too. Though urethane uppers tend to squeak/rattle esp in the cold, best to just get a foam oem-style assembly. Also if your rubber lower bushings are worn, and you're not in some heavily salted/corrosive area, it may be worth thinking about replacement shocks (they come with new bushings as well)
pjprofili
Jun 9, 2018 07:55 PM
RJ237
Apr 16, 2017 03:29 PM
Jon89
16
Jan 18, 2017 02:10 PM
EZDriver
Oct 14, 2012 05:07 PM
