urgent ASAP, i need to know if XJ8 and XJR use the same or differnt gear shifter?
Old Mar 14, 2014 | 08:42 AM
vincent661983's Avatar
Default urgent ASAP, i need to know if XJ8 and XJR use the same or differnt gear shifter?
mine was complete craked into piece yesterday and my car is sitting at the shop now, some say yes and some say they are complete different
Old Mar 14, 2014 | 09:00 AM
ok, I called the dealer and confirmed they are very different about where linear switch
Old Mar 14, 2014 | 10:32 AM
ok, I found a XKR shifter within NY state 2 days shipping and wondering if they are the same part
otherwise there is only one XJR shifter online from LA takes 5 days-shipping
I am debating between time and distance now,
Old Mar 14, 2014 | 11:33 AM
DavidB's Avatar
Yes, the XKR and XJR shifter assemblies should be the same, assuming the XKR is a five-speed Mercedes year (2002 and older) and not the six-speed ZF (2003 and newer).
Old Mar 14, 2014 | 11:45 AM
thanks, David. I believe they are the same. with respect to say, anyone else could also confirm that with me, I am about the call the seller to place the order, I am running out of time. please help me
Old Mar 14, 2014 | 03:29 PM
plums's Avatar
Lookup the part numbers for both. If the numbers match, then they are the same part.
Old Mar 20, 2014 | 01:00 PM
ok, found one for XJR according to the seller it is from an "R"
I called my mechanic,he said he could not just swap the whole sifter assembly in my car but salvaged some parts from my old shifter and some needed parts from yours to rebuild a shifter. no doubt he charged more labor than I expected
why why
Old Mar 20, 2014 | 01:30 PM
XKRacer's Avatar
I just did this today and fitted a XJR J Gate to an XKR and I checked the part numbers on the back, apart from manufacture date they were identical
So visa versa.......
Old Mar 20, 2014 | 01:40 PM
that should work, right
the only thing is the gear shift illumination does not lid up now, seller told me he tested his before shipping to me
dsnyder586
Dec 29, 2024 07:39 PM
tomsjag
Jun 10, 2023 10:02 AM
neruda
Oct 18, 2015 01:19 PM
Phil G.
Sep 12, 2015 07:42 AM
