Vapor lock issue?
Old Nov 15, 2023 | 11:01 AM
thelegend0210's Avatar
Default Vapor lock issue?
So this morning I started the car using the remote start. Went out after 5 mins or so, got in, put the key in and all seemed fine. Was sitting there for a minute and the engine started to sputter like it was losing power. Was getting a few error messages popping up...Traction Control Fail, Stability Control Fail, Engine in safe mode. So I turned the car off, it wouldn't restart on first try, so let it sit for a few seconds and tried again and it started fine. No error messages, no lose of power. I stopped for gas on the way to work and when I took the gas cap off it sucked in a huge amount of air. How likely is it that it was a vapor lock and that was causing the engine to sputter?
Old Nov 15, 2023 | 12:33 PM
Quadcammer's Avatar
Unlikely as car was not super hot and modern fuel injected systems at 40psi should not have such issues if operating properly.
Old Nov 15, 2023 | 12:39 PM
Yeah, after reading about vapor lock this morning it's not likely the issue as someone suggested.
Old Nov 15, 2023 | 01:34 PM
motorcarman's Avatar
Check your CCV. (Canister Close Valve)
Old Nov 16, 2023 | 07:02 AM
Hooli's Avatar
That valve had failed on mine & I couldn't find a second replacement after the first replacement failed shortly after fitting. Turns out you can pop the body open & remove the gubbins inside. Put the case back together & refit it so it looks totally standard. So any inspection you might have that checks it, sees what appears to be a complete working system.
Having said that. The amount of stories of imploding tanks suggests the pump will overcome the partial vacuum with no effect on the car running, I certainly didn't feel any performance difference when my car had that issue.
Old Nov 17, 2023 | 11:35 AM
Quadcammer's Avatar
I have an extra CCV kicking around, let me know if you need it.
Spud Maat
Nov 27, 2021 07:01 PM
4x4uk
Jan 19, 2018 11:25 AM
plmmd
Jan 11, 2016 12:21 PM
jagjunky
Nov 25, 2012 12:42 AM
rigmover2307
XJ40 ( XJ81 )
Aug 11, 2010 09:12 AM
