Very sad post today.
Old May 9, 2024 | 05:58 PM
Quadcammer's Avatar
More holistically, I'd have the car evaluated by a professional to see the full extent of the damages. No sense putting in a new hub if the unibody is bent and there is a bunch of other damage
Old May 9, 2024 | 08:52 PM
Addicted2boost's Avatar
Can you provide us with a picture of the exterior damage?
Old May 9, 2024 | 09:46 PM
ericnunez's Avatar
Ah, I left the car at work and I'm home now. But don't worry, the body is perfectly fine all around, a few scratches on the rear right but thats all. I must have scraped against the light pole while spinning. I looked under the car and honestly, everything seems fine except for the rear right hub carrier, spring, brake, and brake line. I think that's where most of the impact was. That rim is totally cracked into large pieces as well.
Old May 9, 2024 | 09:48 PM
ericnunez's Avatar
Fair point. I'll have my mechanic come and take a look at it first. He's a chill guy, so he shouldn't have trouble with doing it. He's the type of guy to only charge you for the gas he used to get to you.
Old May 10, 2024 | 07:52 AM
I knew the rim would be toast. It’s a good thing that hub carrier is aluminum vs steel or else that energy would’ve carried even further. I think your best bet would be to get a complete rear end assembly and swap it over. I imagine that the right side axle took big hit and maybe caused some differential damage? 🤷‍♂️
Just swap your brakes over and perhaps renew the diff fluid while it’s out before going back in with another assembly. Something to consider.
Old May 10, 2024 | 02:25 PM
RandyS's Avatar
I totally agree with the rear end assembly swap. No sense in making assumptions
that could exasperate you later.
Old May 10, 2024 | 02:46 PM
ericnunez's Avatar
Thanks for the advice. Yeah I might just do that instead. Let me see what the mechanic says in a couple weeks and I'll update then.
CurtJ
Jul 15, 2022 05:17 PM
Jagboi64
Feb 16, 2017 02:09 PM
bigcatdaddy99
Sep 1, 2014 11:48 PM
VanJaggerstien
Feb 15, 2013 02:05 PM
dozierl
Feb 20, 2010 08:10 PM
