VVT making noise at startup
Old Oct 12, 2009 | 03:57 PM
goldencharriot's Avatar
Default VVT making noise at startup
Hi,
After I replaced the secondary tensioners on my 99 XJ8 a loud clack clack clack sound shows up at startup after sitting for a while. It doesn't happen when the engine is warm.
After reading some other threads I'm guessing that this is oil draining out of the vvt unit? I don't have any CELs or anything. Im not sure why that would show up after a tensioner replacement, I didn't mess with it at all.
What is the best course of action to fix this? Is there a seal or something that I could replace or would it have to be the entire unit?
I cant even find any vvt related seals of any kind online .
There is also a high pitched squealing sound at about 1500-1700 rpms when driving, not sure if thats related or not.
Old Oct 12, 2009 | 07:19 PM
Thermo's Avatar
Veteran: Navy
Charriot, it sounds like to me that the tensioners are loosing their oil supply when the engine is off and when you start the car, they are having to fill back up and re-apply pressure to tighten up the chain slack. You don't notice it on start up with the engine warm because the pressure is still built up in the tensioner. As for a repair, I will leave that up to someone else.
Old Oct 12, 2009 | 07:29 PM
StrateLoss's Avatar
I'm in for more info. My xj does this too. only when sitting for a while (4 hours or so)
the only way to avoid it is before cranking the motor, i leave the key in the 'on' position untill the beep stops, then you can hear buzzing. once that stops i crank and no rattle.
i kind of treat it like a cold start on a diesel motor, allowing the glowplugs (vvt) to warm-up (build pressure) before cranking.
SD96XJ6L
Jan 12, 2022 04:30 AM
Rivguy
Dec 4, 2020 07:55 AM
1LowCat
Feb 23, 2016 07:19 AM
raulan
Sep 10, 2015 12:43 PM
jfitzoz
Sep 7, 2015 04:28 AM
