Warning chime / key fob error
Old Dec 11, 2023 | 08:14 PM
pcolapacker's Avatar
Default Warning chime / key fob error
With key out and lights off, when driver door opened warning chime goes off. When try to use remote to lock, unlock or open boot get error beep. I’ve checked that all doors and boot closed.
Old Dec 11, 2023 | 09:49 PM
Addicted2boost's Avatar
I believe that little door in the ignition switch is sticking open when it should be closing as soon as the key is removed. It will also prevent some (if not all) the modules in the car from going into sleep mode. I would use a dry graphite lube for all the key holes in the car.
Old Dec 11, 2023 | 09:55 PM
That was it. Fixed. Thanks.
silvertonesx24
Sep 10, 2023 05:24 AM
IanMat
Jun 16, 2022 06:06 PM
Redhead
Feb 21, 2016 06:18 AM
JaguarXF2008
Apr 14, 2015 02:42 AM
Freebird
Dec 29, 2014 03:49 PM
