Water distribution pipe
Hi fellows,
I just picked up my 2001 XJ8 from the shop because of a burning
smell. They diagnosed the problem as the water distribution pipe
needs to be replace. They wanted almost $1200 to replace this
simple looking part that cost around $65.
Since it's located right on top with easy access, I've thought
about trying to replace it myself.
Any insight/advice?
Any insight/advice?
Received 2,187 Likes
RE: Water distribution pipe
the plastic pipes, t stat housing tend to kinda dissintegrate and get really soft with time. So they were shouting the housing, crossover pipe, rad hoses, but should be doing the heater hoses that go under the intake since you have to lift the intake to get the back 2 bolts out of the t stat housing, so might as well also change these hoses too. Yes you could do it, its alittle bit of a PIA if you dont know the tricks, and or are short on patience, cause the back clamps on the heater hoses are difficult
'Scuse me for butting in.
Manufacturers use different nomenclature, and sometimes mechanics employ jargon, to identify various components. Even the part numbers change from time to time, but those will always get you to the truth.
Jaguar cataloging identifies the plastic crosoverpipe at the front of the cylinder heads:
Outlet pipe AJ8 2216
Turns out this part number for the same item supercedes to:
Outlet pipe AJ8 5885
Jaguar suggested list price is $56.00 for this item.
It's more difficult for a customer to establish a fair labor time for specific repairs, that information is not so readily accessable to my knowledge. But any estimate, and certainly any repair invoice, should list the part numbers of components used in the repair. That way you can verify pricing independentlyif you wish, and certainly make sure you aren't paying twice for the same parts replacement.
Alot of shops (and someparts suppliers) sell items far in excess of Jaguar list prices, and I'm not sure how they can get away with it in this information age. I have customers come in regularly who have either sourced their own parts, or who will call to my attention a better aftermarketprice for anitem I have estimated. And I always have to research new parts prices when I am selling used parts, to make sure that I am offering a substantial savings.
All of this becomes moot once you find a shop you can trust, and it doen't read like you have one yet. Ask them for the factory part numbers and do a little homework.
FS[NorthWest]: XJ8 / XJR 3" Mina Gallery Intake Pipe only (For X308)
xjrjag
10-12-2015 03:16 PM
bydand
09-28-2015 09:47 AM
