Water Leaking Onto Drivers Side Floor Board
Old Jul 19, 2015 | 11:32 PM
xjrjag's Avatar
Default Water Leaking Onto Drivers Side Floor Board
First time I've run my 98 XJR through the car wash since I bought it. Heard a trickling noise all of a sudden, looked around and then saw a pool of soapy water on the drivers side floor board. Funny thing is, afterwards I looked up under the dash and didn't see any water anywhere. Stuck my hand up high toward the firewall, above the brake pedal area and felt behind some wiring / insulation and it was wet.
Would this indicate the windshield leaking or?
Old Jul 20, 2015 | 06:16 AM
RJ237's Avatar
More likely the drain under the hood is plugged. I don't have a XJ8 to look at, but I'm sure someone on the forum will be able to direct you if you can't find it.
Old Jul 21, 2015 | 10:01 AM
xjrjag's Avatar
Regarding my interior leak. I sprayed water on the windshield and under the cowl area and noticed the water was just pooling up under the cowl and not draining. There's one drain hole on the plastic cover underneath the wiper motor. I found a rubber flap covering the hole...I assume it is supposed to be there and allow for the water to drain slowly? Not sure...well, I grabbed that and it just came out altogether and the water dumped out. I'm fine with not having it in there.
However, I found the leak was coming from a split seam in the panel under the cowl area. Right where the two metal panels join. There is supposed to be a sealant there that had split, allowing the water to leak into the car. I sealed the split, and will see if the leak is taken care of tomorrow after everything is cured up.
Old Jul 21, 2015 | 10:33 AM
Jhartz's Avatar
Clean the dirt out of the rubber flap and reinstall it: it diverts water for a reason.
What did you use to seal the split (did it work?)?
Old Jul 21, 2015 | 06:38 PM
xjrjag's Avatar
I would reinstall it if it actually let the water drain out, which it did not. The water pooled up in the are below the cowl and did not drain.
And I have not checked to see if the repair worked or not. Going to go spray it down here in a bit.
Old Jul 22, 2015 | 01:47 AM
xjrjag's Avatar
Conclusion: The repair I did fixed the leak. Sprayed down the windshield and space under the cowl and not a drop under the dash. Success.
99xk8guy
Sep 29, 2025 10:51 PM
mbergen
Oct 23, 2019 10:26 PM
sogood
Sep 15, 2015 07:35 AM
tberg
Sep 7, 2015 07:32 AM
Dallas XK8
Sep 3, 2015 12:17 PM
