Weak Idle when starting
Old Apr 5, 2008 | 08:28 AM
drog321's Avatar
Default Weak Idle when starting
I have a '98 XJR with 92,000 miles. Sometimes when I start the car, it has a very weak idle, and I am able to change the position of the shifter, but the car does not go in to gear (the car will just roll). Turning off and restarting the car always solves this problem.
Any ideas?
Thanks!
Old Apr 9, 2008 | 02:37 PM
skanoski's Avatar
Default RE: Weak Idle when starting
Have you let it idle long enough to see if a restricted performance light comes on? I think it takes about 2 minutes at idle. If you have a code, that will help diagnose.
Old Apr 9, 2008 | 05:28 PM
JagtechOhio's Avatar
Inconsistant idle quality on cold start can sometimes be caused by low fuel pressure on XJ8. This is the first symptom of intermittant connection to , or operation of, the fuel pump. You will not get a DTC if this fault is present.Have someone test the fuel pressure before a cold start to see if this suggestion might be relevant. There are many other possible causes but this is one I have seen and is easily confirmed or denied.
Old Apr 9, 2008 | 06:55 PM
FactoryJaguarTech's Avatar
I love my fuel pressure gauge.
Old Apr 9, 2008 | 07:26 PM
jag_genius's Avatar
change the position of the shifter??
Old Apr 9, 2008 | 07:40 PM
Sounds like dual linear switch fault? Bring shifter out of park, but wont engage gears. Cycle ignition and is fine.
Weak idle though is probably unrelated. Fuel pressure problem is likely. But could be vacuum leaks...clogged breather. Anything really without more info.
aholbro1
Dec 29, 2024 06:46 PM
joesoap
Sep 10, 2015 01:09 AM
OkieTim
Sep 8, 2015 04:48 PM
giandanielxk8
Sep 6, 2015 07:21 PM
OkieTim
Sep 2, 2015 12:48 PM
