What Could Cause This "Steering Issue?"
Old Jun 24, 2011 | 02:22 PM
SirJag's Avatar
Default What Could Cause This "Steering Issue?"
Hello Gentlemen:
I never noticed this before I had new front shocks and new tie-rods ends installed, but I've recently noticed that when I drive over the smallest of road imperfections, the steering wheel moves slightly left or right.
I know for a fact that I need lower control arm bushings and this is yet to be done.
In addition, I'm also going to install:
4 Front upper control arm bushings
2 Subframe bushings
2 Lower + 2 Upper ball joints
2 Sway bar bushings
Can someone please tell me what this odd sensation might be caused by?
Thanks so much!
SirJag
Old Jun 24, 2011 | 02:38 PM
plums's Avatar
If it is minor, it is "bump steer". The relationship of the parts controlling the steering geometry changes on compression or rebound. Particularly the relationship to the tie rod ends. (hard to explain without writing a screed).
Most cars do it, unless it is a race car that has been "bump steered. FWD/AWD cars are also subject to "torque steer".
It is predictable which way and how much a particular car will bump steer, but not usually known to most street drivers.
Still, an experienced driver in their usual car will instinctively nudge the steering wheel one way or the other when say, hitting a dip on a sweeping onramp at speed, to compensate for the bump steer effect. They just "know" from experience.
Old Jun 24, 2011 | 02:44 PM
SirJag's Avatar
Thanks, Plum. What you wrote makes sense, however this seems like there's something wrong. I can't image an originally $70,000 VDP is supposed to drive this way. I never felt this in cars of considerably less quality than this one.
I wonder if the new shocks have anything to do with it... or something my mechanic did in the process of installing the shocks or tie-rod ends. OR, those lower control arm bushings, along with the new shocks and tie-rod ends, are causing that feeling to be amplified?
Can you tell I'm speculating?
SirJag
Old Jun 24, 2011 | 02:55 PM
plums's Avatar
Well if it's that bad, maybe something is still loose from the last bit of work. Report it to your mechanic. No mechanic wants a customer car to go off the road due to loose fasteners etc.
Old Jun 24, 2011 | 02:56 PM
SirJag's Avatar
Will do... thanks, Plum.
SirJag
H20boy
Dec 24, 2024 03:23 PM
rusty37
Apr 5, 2020 07:40 PM
PMKimpton
Aug 3, 2019 08:22 PM
sogood
Sep 15, 2015 07:35 AM
AL NZ
Sep 4, 2015 08:39 PM
