Where Can I Find Negative Battery Terminal End With Small Hole
Old Aug 30, 2018 | 10:52 PM
astark's Avatar
Default Where Can I Find Negative Battery Terminal End With Small Hole
I want to have made the short negative battery cable but having a hard time finding the terminal end that connects to the post at side of trunk. Is it likely to be found at a welding supply store or can you suggest where to look. Also, what gauge cable wire would you recommend for a heavy duty better than original equipment cable.
Old Aug 31, 2018 | 03:35 PM
Carnival Kid's Avatar
You should be able to find negative battery cables of varying lengths at any autoparts store.
Old Aug 31, 2018 | 07:05 PM
avern1's Avatar
astark, what seems to be the problem that makes you think a bigger ground cable is necessary? I have the original and it is sufficient. I have had some corrosion on the other ground points that required maintenance.
Old Aug 31, 2018 | 09:00 PM
astark's Avatar
I just like heavy duty cables, got some double 0 copper cable for free from a friend at a welding supply store, had some exceptional quality ends from an old fashioned auto parts store crimped on after not being able to find the trunk end I had hoped might be available somewhere, so I just used a couple of copper washers I got at the hardware store to snug fit the other end from battery post. Total investment in a super heavy duty cable was just a few cents over twelve dollars and its mighty nice, much nicer than a seventy five dollar OEM or six dollar standard off the shelf auto parts store.
I had been having negative battery cable problems with the original which included intermittent total power loss, even after cleaning and didn't feel like messing with it anymore, and finding it more fun to create the new one that I did :-)
Salu498
Aug 13, 2016 12:29 PM
Compounder
Jan 13, 2015 05:58 PM
nslkevin
Jul 14, 2012 09:23 AM
jaguarcraver
Mar 9, 2011 03:42 AM
nsl1
Mar 1, 2011 06:12 PM
