Where are the screws/bolts that hold the front grill in place?
Old Oct 20, 2010 | 09:44 PM
newuser's Avatar
Default Where are the screws/bolts that hold the front grill in place?
Looks like my grill was removed at some point when they painted the front bumper but they didn't put it back correctly. There's a big gap on the top so I need to loosen the screws and readjust it. Does anyone know how I can do this? Thanks
Old Oct 22, 2010 | 08:36 PM
Rae's Avatar
Rae
newuser: I have a 99xj8 and my screws are located 2nd slot in from each end. T30 Torx bit will work. As the grill is plastic, I did not see much of a difference when I tried to close my gap. Loosened all four, pushed in & held in place, while tightening. There really should be center screws, poor design.
Ralph
Old Oct 24, 2010 | 07:49 PM
newuser's Avatar
Ralph
Not sure what you mean by 2nd slot in. Do you get to those from inside the engine compartment (with the hood up) or from the outside? Thanks
Old Oct 25, 2010 | 07:10 PM
Rae's Avatar
Rae
newuser: To clarify, I presume we're talking about the grill between the headlights. Outside, hood up or down, makes no difference. Look into the front of the grill with a flashlight if need be, you should see two screws located behind the vertical ribs outboard edges. If you have aftermarket mesh grills, I would think the screws would still be in the same place. Unless I've misread something, this should have you in the right place.
Ralph
dsnyder586
Dec 29, 2024 07:39 PM
PMKimpton
Aug 3, 2019 08:22 PM
al_roethlisberger
Sep 11, 2015 10:04 PM
AL NZ
Sep 4, 2015 08:39 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
