whirling sound from dash???
Old Aug 28, 2011 | 02:16 PM
bone64's Avatar
Default whirling sound from dash???
Hello again. I have a curious sound coming from the passenger side of the dash but lower down. It sounds like a motor whirling slowly in the background but continues even after I shut off the HVAC system. It stops very quickly after the engine is shut down. Any thoughts? It does not change if i try to change the HVAC settings for temp or direction.
Old Aug 29, 2011 | 03:53 PM
Sean B's Avatar
the ecu has a cooling fan that vents into the cabin in the area you pin pointed. it's a standard type 12V 80mm by 80mm computer cooling fan. might need replacing if noisy.
Forcedair1
Feb 19, 2020 01:51 PM
cyber3d
Sep 15, 2015 02:37 PM
jagent
Sep 12, 2015 01:40 AM
vincent661983
Sep 10, 2015 05:52 PM
1964Daimler
Sep 9, 2015 11:28 AM
