Wider rear tires on '02 XJR?
Old Oct 29, 2019 | 01:05 PM
64etype's Avatar
Default Wider rear tires on '02 XJR?
I really like the Astriod wheels on my car, but would like to use wider rubber on the rear, and also push the wheels slightly outboard. It looks like 275/40-18 rubber would fit..The diameter is just very slightly larger than the 245/45 currently on the car. The minimum rim size for that tire size is 9 inches. So, I'm thinking about having the rear wheels widened 1 inch by a well know wheel shop, and then adding a spacer to move the wheels outboard about 1/2". That would fill out the wheel well nicely and also distribute the wider width evenly on the bearing/hub carrier. Has anyone done this? Comments"? (No, I don't want to switch to a different wheel).
Old Oct 29, 2019 | 02:25 PM
motorcarman's Avatar
Why not just find some XKR wheels. I think they already use 9 rear and 8 front wheels.
bob
Old Oct 29, 2019 | 03:10 PM
64etype's Avatar
I don't believe the Asteroid wheel came in 9 inch. The ones I've seen on XK8s are 8inch front and rear.
Old Oct 29, 2019 | 04:45 PM
I stated XKR (NOT XK8)
Apollo
9JX19" for rear
8JX19" for front
Impeller
9JX18" for rear
8Jx18" for front
Many choices.
5 Spoke
7 Flute
Apollo
Detroit
Double Five
Impeller
Lamina
Milan
Montreal
Paris
Old Oct 29, 2019 | 05:26 PM
64etype's Avatar
I think our wires are crossed. As I said in my original post, I don't want to change to a different wheel from the Asteroid (which was only offered on the XJs and XK8 from what I can discern). Anyway, I found a couple of wheel modifiers (one local in Dallas) that seem to have a decent reputation.
Cardog
Aug 30, 2016 08:46 PM
JonWat
Apr 22, 2016 08:30 PM
richzak
Jan 10, 2014 03:58 PM
Jeff in Tucson
May 26, 2012 09:29 AM
Craig Schmidt
Oct 26, 2011 05:54 PM
