will 38 mm offset fit xj8?
Old Mar 27, 2008 | 08:02 PM
iamitltproof's Avatar
Default will 38 mm offset fit xj8?
will 19x8.5 inch rims with a 38 mm offset and 245/35 tires fit on a 2000 xj8 with out clearence issues?
Old Mar 28, 2008 | 07:44 PM
Default RE: will 38 mm offset fit xj8?
can anyone help me with this?
Old Mar 30, 2008 | 12:19 PM
does anyone know where i can find this info?
Old Mar 31, 2008 | 07:11 PM
MarkC's Avatar
I wouldn't trust a simple "yes" or "no" answer from anyone on the internet. They just might want to sell you wheels or tires.
I would suggest you start by measuring the minimum available clearances you have now with the existing (stock size?) wheels and tires. Check inside and outside clearances front and back. On the front, check clearances with the wheels turned full left and full right as well as straight ahead. Then determine the offset and width of the present wheels, as well as the treadwidth, sidewall width and diameter of the present tires. Make an accurate drawing of the present setup with respect to the inner mounting surface of the wheel, then overlay the new wheel and tire dimensions on the same drawing. From this, you should get a reasonable idea of how the minimum "static" clearances would be affected with the new wheels and tires. Assume these clearances will only get smaller when everything is moving and flexing.
dsnyder586
Dec 29, 2024 07:39 PM
DrTripp
Mar 22, 2020 09:33 AM
Forcedair1
Feb 19, 2020 01:51 PM
ferraripete
Sep 10, 2015 01:24 AM
wcourt3010
Sep 9, 2015 04:34 PM
