windows go down
have a red blinking light on gear shift . want start. when i try to lock and unlock the door all the windows go down as soon as i start to turn key. no remote.
These old Jags do some weird and wondrous things if their battery is not 100%
okay people it's not the battery(wish someone would come up with something diff) have 5 others. 1 98,2 99's, 2 2000's. put the battery in each one for a day. no problems. changed out key/transponder from another and it turned over for a day. then found out bad fuel pumps. changed out ,now back to square one. will not turn over. now i found out the other 2000 windows come down about two inches when i unlock.not good when it's rainning
I found these other posts on "no crank"
"99 XJR won't start, just a "CLICK" noise" thread - Forum member Sean B comment: "The false bulkhead connector, a heavy black cable bolted to the brake pedal assembly cover and a similar cable that runs to the fuse boxes and interconnects try unbolting them and checking the connections tidy them up with sandpaper/wire wool..... A freshly charged battery too."
2nd thread - " Help! Car won't start - Hoping i didn't fry something"
Here is link to my post there --- has information about the fuses and false bulkhead connection:
https://www.jaguarforums.com/forum/x...66/#post921521
Jim Lombardi
Jim Lombardi
philwarner
28
Jul 11, 2017 10:21 AM
blackenedindustries
Sep 30, 2015 10:17 AM
