windshield wiper problem
Old Jan 26, 2011 | 09:17 AM
janbache's Avatar
Default windshield wiper problem
Hi there.
My 02 XJR's windshield wiper is driving me nuts. The mechanism works OK, but it leaves huge streaks in the middle of the windscreen and the blade doesn't even touch the windscreen in the bottomright and left corner.
I have changed the wiperblades many times and the best results so far are with universal flatblades. "Normal" wiperblades are more or less useless.
It looks like the arm isn't applying enough pressure unto the blade.
Do any of you have any good suggestions as what to do?
Thanks in advance.
Old Jan 26, 2011 | 10:13 AM
test point's Avatar
The easy answer is to replace the arms. Maybe they were bent at some time in the past.
Old Jan 27, 2011 | 03:22 PM
SuperSport's Avatar
Originally Posted by janbache
Hi there.
Thanks in advance.
I've tried to tighten the springs, and also bent the arm a bit. Bending the arm inward worked best. Obviously, be careful trying this. It's still not perfect, but at least the middle is getting cleaned now.
jfitzoz
Sep 7, 2015 04:28 AM
mcdutch
Sep 4, 2015 03:38 AM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
XJsc-guy
Sep 2, 2015 11:43 AM
