Wishbone tie bush, is it available?
Old Sep 30, 2019 | 01:39 PM
owas's Avatar
Default Wishbone tie bush, is it available?
On the wishbone tie bar that connects the two rear wishbones with the inner fulcrum bolts, behind the head of the bolt, I can't see anything on the parts diagrams, is it a bush I can change? I've used alot of heat in the area so it's probably US at this point.
My expensive rear end shopping list is almost complete
Old Sep 30, 2019 | 11:34 PM
nilanium's Avatar
https://parts.jaguarlandroverclassic.../brand/jaguar/
part 5 maybe? or 10/11? A bit hard to tell from the diagram there, site got updated and it's a bit harder to read now
Old Oct 1, 2019 | 01:20 AM
M. Stojanovic's Avatar
The parts catalogue does not show any bushes as separate items for the #6 Wishbone Tie. If there are rubber bushes inside it for the fulcrum bolts, they may be the same as the bushes #19 that are for the other end of the fulcrum bolt, in the #17 Pendulum.
Old Oct 1, 2019 | 04:02 AM
owas's Avatar
After going through quite a lot of old threads, I found someone mention it is the same as the lower pendulum bush
Old Oct 1, 2019 | 02:47 PM
owas's Avatar
I struggle with that site after the update, I just use sng's site instead, much more user friendly
Old Oct 2, 2019 | 10:48 PM
nilanium's Avatar
I noticed that as well, I had it as my go-to since it followed the factory parts list setup so closely, but the recent update (past few months or so? Haven't used it in a while) is much worse to navigate. I'll check out the SNG catalog
Man on the hill
Jun 24, 2018 07:29 PM
Maraud
Jun 13, 2017 04:38 AM
blackjack1
Jun 17, 2016 04:55 AM
plums
Sep 20, 2015 05:30 PM
pinch
Jul 6, 2014 08:40 AM
