Won't Crank. Please help!
Old Jul 30, 2014 | 03:23 PM
moped64's Avatar
Default Won't Crank. Please help!
Hello everyone,
I own a 2000 Jaguar XJ VandenPlas. Recently, the dashboard bulbs behind the instrument panel went dark. I checked the relevant fuses (with the battery disconnected) to see if they were blown but they were ok. So I set out to replace the bulbs and got it done quite easily. The problem was afterwards, when I went to start the car, it wouldn't crank. The lights (interior and headlights, as well as the instrument panel), radio, locks/windows, etc all work just fine when the key is in position "II". But when I go to crank it, the engine doesn't turn over. I don't hear any sounds either. Before I started work on the dash lights, I was sure to disconnect the battery (I disconnected the negative terminal). I think (but not sure) I took the keys out of the ignition. Also, a warning message came up saying the trunk door was open even though I had shut it. I went and checked a couple of fuses but they were all good. After that, the trunk message went away but the car is still not cranking. Any suggestions?
Old Jul 30, 2014 | 09:03 PM
sparkenzap's Avatar
Yeah, check the battery voltage with the headlights on at the battery and again under the hood at the false bulkhead connectors. e can go from there.
n2audio
19
Jan 20, 2025 09:35 PM
jluckcuck
Nov 6, 2015 07:49 AM
audibabba
Oct 4, 2015 05:41 PM
blackenedindustries
Sep 30, 2015 10:17 AM
Listers
Sep 30, 2015 07:45 AM
