X308 Rear Hub Nut
Old Sep 12, 2023 | 04:27 PM
accsol's Avatar
Red face X308 Rear Hub Nut
For reasons not necessary to go into here, I have recently had to remove the rear hub nuts, both sides.
These are described through Jag manuals etc. as "do not re use".. I believe they have some form of helicoil within.
I am getting quite collection of such nuts
Some of them are clearly not re-usable, others have what appears to be the helicoil within and look no different to a brand new one. I'm tempted to reuse the "good" ones - perhaps with Loctite? Buying new ones every time is becoming a tad expensive!. has anyone any experience in this area, or can offer alternatives?
Thanks for any help
Accsol
Old Sep 12, 2023 | 05:45 PM
Addicted2boost's Avatar
Well, we had a forum member about 3ish years ago lose control of his 01’ Supercharged Vanden Plas just taking a mild turn, lost control abruptly and ended up in a ditch. The car was a total loss. The kicker is that he just had a business do rear wheel bearings and do you think they replaced the nuts with new ones?? Nope! His forum name was Col Sanderz if you want to look it up. The axle nut came off on one side and tilted the wheel over towards one side as he was turning a corner.
Btw, congratulations on your very first post being a 10 year member. 😂
Old Sep 12, 2023 | 07:49 PM
xalty's Avatar
xjs axle nut and red loctite
little torch action it’ll come off next time
chris-jag
Sep 23, 2019 09:29 AM
jagtoes
Mar 9, 2017 04:37 PM
Rodders59
Mar 27, 2016 10:24 AM
Bondy
Jul 16, 2013 11:23 PM
CharlesF
Sep 6, 2009 06:09 PM
