X308 - silent turn signal clicker
Old Jul 10, 2014 | 03:29 PM
gwsmith147's Avatar
Default X308 - silent turn signal clicker
A while ago the clicker as well as the chime reminder that the headlights were on after turning off the car stopped working. The turn signal lights work fine. With summer upon us and with the car sitting in the sun with the windows up it now works - at least until the car cools off. My mechanic wants to go "exploring" - time and materials of course. Any ideas??
Old Jul 11, 2014 | 03:35 PM
Fraser Mitchell's Avatar
Funny that, my latest car purchase, an MG TF has a silent "clicker" when I signal to turn right, but its OK when I indicate to turn left ! Indicators work perfectly. So whatever it is that make the sounds seems to have failed. It may be a software generated noise output on a speaker, so the speaker may have failed. Any other tones missing ?
Old Jul 12, 2014 | 09:31 AM
gwsmith147's Avatar
My problem is with a 2003 Jag XJ8 although this was my first "post" so I'm not sure it was clear. Is there a way to edit my question to include that info? As to your question, the only other tones not working properly that I know of is for the chime which sounds then the headlights are on manual and I turn off the auto.
Old Jul 13, 2014 | 08:21 AM
I've edited your thread title and moved it to X308 forum.
Old Jul 13, 2014 | 10:52 AM
bcinguu's Avatar
The clicking and chiming sounds you hear are actually produced by an old-fashioned speaker inside the steering column cover. Look closely at the column near the ignition and you'll see the small holes where the sound comes out.
Remove the attaching screws underneath the column, remove the plastic column cover trim, and you will see the speaker on the right side. They do go bad. You can find a replacement at Radio Shack, your favorite electronic parts store, or online.
Old Jul 13, 2014 | 10:53 AM
motorcarsrandy's Avatar
speaker on right side of column goes bad or wire breakes from repeated tilting. Had to replace mine due to an open speaker.
Old Jul 15, 2014 | 01:54 AM
Distraxi's Avatar
What they said. It'll be the speaker. But before you fix it, consider whether you really want to. Took me a few months to get around to doing mine, then when I did I immediately disconnected it again because the ticking pissed me off. Silence is very soothing....
Old Jul 15, 2014 | 07:30 AM
NJ2003XJ8's Avatar
I had similar problem, sound would come back sometimes but than disappeared completely. Replaced speaker and all good now. I added a resistor to the replacement speaker to keep the same resistance, just in case.
Forcedair1
Feb 19, 2020 01:51 PM
mbergen
Oct 23, 2019 10:26 PM
Richard_gib
Sep 12, 2015 07:08 PM
tonyforman
Sep 10, 2015 07:23 PM
jaguarbill
Sep 5, 2015 11:43 AM
