X308 spark plug recommendations
Old Apr 28, 2009 | 07:42 AM
nicknack's Avatar
Default X308 spark plug recommendations
Hey guys, looking for some help in selecting new spark plugs for my 03' XJ8. Bosch, NGK ???
Old Apr 29, 2009 | 01:39 PM
nicknack's Avatar
Just ordered per my local Jag dealershipNGK
Spark Plug IFR5N10 NGK; Iridium Spark Plug
For models with production year from 1999. For models with chassis serial number from 853936.
Note: Iridium Spark Plug
Old May 10, 2009 | 11:45 AM
Abe Mirza's Avatar
HI. NickNack,
Why did you pick those particular Spark Plugs and are you happy with theor performance. I need to change mine in my 2003 VDP and need your input. Thanks.
Old May 10, 2009 | 12:36 PM
nicknack's Avatar
That is what my dealer recommended and come to find out that was what it had. So far so good, couldn't bring myself to torque them to the recommended 25 nm, so I just a little over hand tight, the torque wrench never clicked off. so I know I didn't over tighten.
Old May 10, 2009 | 05:28 PM
jag_genius's Avatar
i put the latest plugs from the XF .. so far so good.
Old May 11, 2009 | 09:24 AM
Abe Mirza's Avatar
Default Spark Plug IFR5N10 NGK; Iridium Spark Plug
THank you both Nicknack and jag_genius. It helped.
Old May 11, 2009 | 11:04 AM
wazari's Avatar
Make sure you use an anti-seize compound when installing the plugs. 25nm is not a problem. Obviously you don't want to strip the aluminum threads, but on the other hand a spark plug coming loose is not a good thing either.
Old May 20, 2009 | 03:10 PM
pjkbrit's Avatar
good point!!! No Copaslip....I hava always used regular engine oil on the threads and of course...NEVER overtighten.
Old May 21, 2009 | 02:21 PM
Kid Colt II's Avatar
Just changed out my plugs, bought NGK Stock No. 5464 iridium plugs.
My old existing plugs were also NGK Iridiums.
Old May 23, 2009 | 02:25 AM
Cerberus's Avatar
I've yet to hear a bad thing about Iridiums. That's what we've always ran in the Bimmers as well....
cissdm
May 3, 2016 06:02 AM
BathoryFan
Sep 15, 2015 05:04 PM
Boeingtravel95
Sep 14, 2015 05:01 PM
Pristine97XK8Convertible
Sep 10, 2015 09:24 AM
mrplow58
Sep 9, 2015 11:27 AM
