X308 wheels spacers
Old Mar 1, 2025 | 08:30 PM
Bob Di Janni's Avatar
Default X308 wheels spacers
Si I installed spacers on front and rear. Now both rub occasionally when turning slightly and definitely when I hit a pot hole. Tires are sliced a bit and rubber peeling. I might try gluing a 1" block onto rear steel thing to act as a stop. Or should I consider stiffer shocks?
Anybody "ROLL" their fenders to resolve issue?
Old Mar 1, 2025 | 10:08 PM
Addicted2boost's Avatar
Insert style twist and lock spring spacers.
Old Mar 1, 2025 | 10:36 PM
ixfn's Avatar
I rolled front and rear to clear 255/285's X100 20's comfortably, lowered about 30mm. Easy to do with a heat gun and generic $40 tool from Mr. Bezos. Small intervals is the key, and you may need to mod the tool to fit the hub.
Bob Di Janni
Mar 4, 2025 07:09 PM
powerhouse
Jan 1, 2018 04:23 PM
NavMD
Jan 25, 2016 02:04 PM
Loxmth
Jul 18, 2015 11:11 AM
multistrada74
Jul 9, 2015 11:56 AM
