x308 XJR Valve Stem Seals Replacement
Is it possible to remove and replace valve stem seals in a 2000 x308 XJR without removing the heads?
Is there an accepted process/ procedure for doing so?
Thanks. Best, Harold ...
It’s possible but, if you’ve gone that far, you might as well go just a little bit further and pull the heads and have the machine shop go completely through them including valve adjustment. Get the MLS head gaskets and new head bolts especially being an R car. You’ll be glad you did. Mine ran so much better afterwards.
Upon reflection, I think your suggestion is the direction that I will go in: pull and completely rebuild the heads with new valve stem seals, MLS head gaskets, and head bolts. There is no indication of any problem with the cylinders or block, and attempting to replace valve stem seals in situ appears to be a back-breaking slog.
Thanks. Best, Harold...
If you have no indications of the head gaskets leaking, it is better not to touch them (the usual "If it ain't broke...).
