X308 XKR misfire at 3000rpm
Old Feb 21, 2014 | 03:01 AM
richardgrantham26's Avatar
Default X308 XKR misfire at 3000rpm
Hi all
I have an issue with my beloved XJR. I have spent a small fortune looking into it. The car miss fires at 3000rpm and isn't as smooth as it should be. I had it in at a specialist and they fixed a small air leak and changed the crank shaft sensor.
Just wondering if anyone has experienced anything simular or has any ideas on what the problem could be?
Thanks in advance
Richard
Last edited by GGG; Feb 24, 2014 at 10:32 AM. Reason: edit typo in thread title so it appears in searches
Old Feb 21, 2014 | 06:03 AM
sparkenzap's Avatar
Any "check engine light" or OBD codes? What are the fuel trims doing at that speed? The fuel pressure? Spark Plug age/?
"Doctor I feel sick in the afternoon. What's wrong with me?"
Old Feb 21, 2014 | 06:22 AM
Hey, thanks for the reply. No codes and no engine light. Full service with plugs done recently, they could be cheap plugs Im not to sure. Not to sure about the other bits but will find out
Old Feb 21, 2014 | 12:36 PM
plums's Avatar
On the XJR of this vintage, there are two fuel pumps and fuel pump circuits. The secondary is used at startup and above 3500'ish rpm. Each circuit has its own fuse and relay.
If the engine cranks a bit long on a cold start, it could point at the secondary going out.
The pumps can be tested individually by jumpering across the proper blade sockets at the relay with key off. Listen for each pump. Should be a quiet "whir". Extended gurgling could be the hose loose in the tank.
After the pumps have been verified to work, swap relays in case the relays are bad.
If you are able to clear codes, or willing to run a couple of times with "restricted performance" showing before it clears, there is another test. The system is designed to work when one relay is bad by using the remaining circuit. The ECM detects a bad relay signal circuit not a bad pump or relay. Pull one of the relays, engine should still start and run well at idle. Replace relay and try same test on the other circuit. Make sure that you run for a few minutes to ensure that it is not just running on residual fuel in the lines. If either test fails, then start sniffing around but it is likely the pump itself.
Old Feb 24, 2014 | 10:25 AM
Sean B's Avatar
is the misfire in neutral parked or driving?
The fuel pumps are an obvious suspect, the secondary cuts at 3000rpm run the checks plums suggests.
Forcedair1
Feb 19, 2020 01:51 PM
duecedriver
Dec 25, 2015 11:47 AM
hhv00586
Sep 18, 2015 08:59 AM
Bcrary3
Sep 11, 2015 10:36 AM
XFR_Gold
Sep 2, 2015 12:24 PM
