xj problems
Old Apr 30, 2016 | 04:41 PM
reece-xj8's Avatar
Default xj problems
hello all I recently bought a 98' xj8 4.0 as a spares repairs car
it is a running car but has its problems (mice under the inlet for starters)
it starts and idles fine but anything more than say 5% throttle and it will start missing or cutting fuel or something
so far ive checked coils and plugs, they seem to be working fine although plugs are a bit carbony
removed the throttle body and cleaned it all out including the sensors
changed a knock sensor as mice had eaten the wire
it came with a spare fuel pump in the boot so I think the previous owner has changed it
have had it plugged into the scanner but theres no codes after I replaced that knock sensor
any ideas about what to check next? will be getting a video of it tomorrow show the problem
Old Apr 30, 2016 | 05:22 PM
Highhorse's Avatar
Check the gap on the plugs, usually over gapped plugs create acceleration issues. I would clean the MAF with a MAF only cleaner and check for any vacuum leaks.
Here's a link for ya you'll find helpful....http://www.jagrepair.com/S-TypeTSB.htm
Old Apr 30, 2016 | 08:28 PM
RJ237's Avatar
Also check the fuel pressure. Maybe the po decided not to change the pump because he couldn't get the fuel line off, or what about the fuel filter
Old May 1, 2016 | 06:42 PM
reece-xj8's Avatar
going to check the fuel filter tomorrow and hopefully get the fuel pressure checked soon, was reading about it and its meant to be at 55psi although that may be for the supercharged version
will change the fuel pump for that other one I have and see if it makes a difference
Old May 1, 2016 | 06:45 PM
reece-xj8's Avatar
gonna check plug gaps too, thanks highhorse the gap should be 1.3mm
Old May 1, 2016 | 07:24 PM
RJ237's Avatar
Fuel pressure about 40 for NA engine.
silversurfer1221
Oct 8, 2017 10:08 AM
trucknetjack
Dec 3, 2016 09:49 AM
dinop
Jun 14, 2016 02:48 PM
garyw77
Mar 27, 2016 10:44 AM
XxSlowpokexX
Mar 25, 2016 07:07 PM
