XJ Sport engine won't turn over
Old Dec 14, 2018 | 07:29 AM
chris101's Avatar
Angry XJ Sport engine won't turn over
XJ sport 3.2 1998
I last started the engine OK a few weeks ago, but now theres just a click (presumably from the starter solenoid). I have checked the battery/connections etc and all are OK (I am an electronics engineer),
so I am assuming that the starter has a problem or the engine has seized with the cold weather, or there is something sticking (film of rust?). I would be most grateful for any suggestions. Thanks.
Chris
Old Dec 14, 2018 | 08:08 AM
Welcome to the forum Chris,
I'll be amazed if it's is not a failing/partially discharged battery or a loose cable connection at the HPPM (High Power Protection Module).
I've moved your question from General Tech Help to X308 forum. This is the place to post technical questions about your model.
Old Dec 14, 2018 | 08:18 AM
chris101's Avatar
Default HPPM
OK - Thanks. I will check the HPPM - if I can find it!
Old Dec 14, 2018 | 08:42 AM
RJ237's Avatar
The HPPM is in front of the spare tire. Have you removed and cleaned the ground strap at the right rear of the engine? Also check for corrosion of the crimp on the battery cables. If all that is good and the battery shows over 12.4 V try tapping on the starter.
Old Dec 14, 2018 | 10:00 AM
chris101's Avatar
Thanks. Its about -5c here and getting dark, so I will leave this until tomorrow!!!
Old Dec 15, 2018 | 09:36 PM
Lady Penelope's Avatar
Feel for the starter relay to click
The fuse links have a habit of coming loose
Old Dec 16, 2018 | 04:39 AM
chris101's Avatar
Thanks for that - I will venture out into the cold and check!
Jag7651
Jan 14, 2019 10:34 AM
Maybe_XJ
Dec 18, 2018 10:14 AM
ben30
Dec 14, 2018 12:59 PM
Blondie
Dec 14, 2018 10:37 AM
Ordhyait
Dec 11, 2018 07:53 PM
