XJ8 2003 MY Differential
Old Jan 17, 2009 | 09:24 PM
joey4420's Avatar
Default XJ8 2003 MY Differential
Okay, so I am doing some maintenance on my '03 XJ8 and I want to change the diff oil, I look around and find what appears to be just one opening in the diff... am I missing something, or is there not a drain and a fill plug?
any help would be great.
Old Jan 17, 2009 | 09:49 PM
Thermo's Avatar
Veteran: Navy
Default RE: XJ8 2003 MY Differential
Joey, odds are, you will need to use a vacuum pump or other similar device to remove the fluid. This device can be picked up from any auto parts store for around $15. Other than needing the vacuum pump, the rest is really easy. I think it took me about 30 minutes to do the rear differential on my X-Type.
Old Jan 17, 2009 | 09:50 PM
Brutal's Avatar
drain plug in the bottom, and fill plug in the back...fill till runs out the back hole and then close back up, and dont crank it, it only takes a snug
Old Jan 18, 2009 | 12:08 PM
joey4420's Avatar
Drain plug in the bottom? Do I have to remove the plate to find it? The only plug I seen was the back. I looked in the hole in the plate and no plug, this is why I ask.
ORIGINAL: BRUTAL
ccismobile
Sep 14, 2015 07:48 PM
Ipc838
Sep 13, 2015 03:27 PM
kabs3012
Sep 12, 2015 10:40 AM
kabs3012
US Midwest
Sep 10, 2015 01:17 PM
AtholC
Sep 9, 2015 09:07 PM
