XJ8 3.2 has a slight " Cough "
Old Dec 2, 2017 | 09:20 AM
HarryGilfillan's Avatar
Exclamation XJ8 3.2 has a slight " Cough "
Good afternoon all , hope someone can shed some light on this.
Vehicle idles nice and smooth and runs ok , however, Ive noticed that if its idling and you put the foot down to rev it , it has what can only be described as a slight "cough" before revving as it should , any ideas/thoughts?
Old Dec 2, 2017 | 09:39 AM
JagV8's Avatar
Could be anything from a faulty plug, coil, cat, ...
You might have a look at fuel trims and also for pending codes in the hope of clues.
Old Dec 2, 2017 | 10:16 AM
No fault codes showing, coils were replaced a few months ago but runs great out on the road, just noticed it really the other day but looking to try and solve a "minor" issue before it becomes a "major" one , thanks
Old Dec 2, 2017 | 10:48 AM
Jhartz's Avatar
Had the same issue with my last 308 before I bought it. Once purchased, Cleaned the MAF, the throttle bore and plate and made sure the air duct was tight -- issue resolved. I think cleaning the throttle bore and plate did the trick. New plugs, air filter, and secondary tensioners, later.
Old Dec 2, 2017 | 11:39 AM
Sound. Will give these a try and see how it goes
