XJ8 Auto Lights feature fail
Old Nov 17, 2010 | 07:51 AM
teejay246's Avatar
Default XJ8 Auto Lights feature fail
My Auto Lights feature stopped working. Lights work OK and dimming Mirror works and wing mirrors. Anyone any fixes?
Old Nov 17, 2010 | 12:39 PM
JaguarXJR02's Avatar
could be something to do with the sensor which is that big apparatus near the rear view mirror that is glued onto the windscreen. Have you had your windscreen replaced. If that isn't the problem I suppose there could be some type of problem with the wiring somewhere
good luck
Old Nov 17, 2010 | 03:24 PM
Sean B's Avatar
good luck
That's auto wiper fixed to the screen, the light sensor is in the rear view mirror....
Do the side lights work?
It could be a wire broken loose pn the stalk, I had no auto lights and found two wires off the little board they were supposed to be fixed to, I luckily had a spare so swapped them. You have to disconnect battery and leave for 10 mins, then remove the airbag from the wheel, , then look for the wires and their connections to the column. They can be easily re-soldered back on.
Old Nov 18, 2010 | 02:13 AM
DavidN's Avatar
On the back of the rear view mirror there is a "control dial" to adjust the sensitiveness of the auto light switch. Its a black round pin-like thing.
Maybe the electronics inside is slightly corroded and it helps to turn it a few times...
Jpav27
Jul 31, 2022 06:43 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
rachelstr
Sep 3, 2015 12:59 PM
pnwrs2000
Sep 3, 2015 11:55 AM
King Charles
Sep 3, 2015 12:40 AM
