XJ8 Blue Smoke on Start Up
Old May 5, 2009 | 11:30 AM
Morgai1's Avatar
Default XJ8 Blue Smoke on Start Up
Hi all.
On starting my jag from cold, I get a very small amount of Blue Smoke that quickly dissapears (within less than 10 seconds), I'm sat here thinking the worst, but I would be most grateful for anyones advice..
Possible valve stem seals? ideas on cost??
Thanks!
Old May 25, 2009 | 03:16 AM
thejagman's Avatar
Default smoking on start up
i have the same problem on my xj8 4.0lt. 1997
I am also loosing oil, 2lts every 1k miles.
my understanding was that it could br the v. guides.
but then i did some askig and the subject of Nicksell coating come up.
If you find any more let me know
Old Oct 8, 2011 | 05:58 PM
plums's Avatar
For the first two posters, just try a slightly thicker grade of oil, say 10W40 instead of 5W30.
Old Oct 9, 2011 | 03:23 AM
Cadillac's Avatar
It might be from valve seals ,mines does it as well . No big deal what I was told
Old Oct 9, 2011 | 07:19 AM
Gus's Avatar
Gus
My 1993 XJS 4.0 had the same puff of smoke on startup I replaced the engine oil to 10w 40w and all was good. If your car seems to use oil try the 10w 40w oil as suggested by keep in mind that a little oil loss between oil change is not a problem. I do not know what is acceptable but today my 99 XK8 & 2000 S-Type use about a quart in4000mi. I change the oil every 5000mi. As an option you could add Restore oil additive every other oil change. Some people call it snake oil I say it works well. It had been recommended by others on this forum I used it in my Rav4 that hat 266,000mi and it worked well.
Wolfy
May 28, 2024 08:06 AM
JarodL
Mar 7, 2024 01:39 AM
Dz1rfj
Jul 17, 2018 10:29 AM
Jaguar Forums Editor
Jaguar Press release
Sep 3, 2015 09:38 AM
