XJ8 Differential oil check location, procedure
Old Mar 10, 2009 | 07:24 AM
jag_genius's Avatar
Yes thy are comon fill is at the back fill till it comes out . Make sure you check the level diffs are pricey
Old Mar 10, 2009 | 10:31 AM
pjkbrit's Avatar
bitch of a job...I still cannot get the right 1/2" extension to fit the fill plug...plus it looks like to drain, you have to remove the lower A Bracket that runs across the rear suspension, or syphon the old oil out without a chance to clean the magnetic drain plug!
Old Mar 10, 2009 | 10:38 AM
jag_genius's Avatar
Sometimes a good pair of vise grips to loosen it off works .
Bcrary3
Sep 12, 2021 05:41 AM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
KarimPA
Sep 12, 2015 08:15 AM
KarimPA
Sep 3, 2015 07:32 PM
OkieTim
Sep 2, 2015 12:48 PM
