XJ8 Eaton M112 questions
Thank you, those injectors may be pushing their limits on this build. I'll run them for now and see if they present and issue later.
They appear to fit well and I'm going to run with them as is, unless a hurdle presents itself down the road I'll then address whatever problem may be.
Question about this mod
There are (basically) three different supercharger/intercooler setups;
4.0L XJR and XKR
4.2L XKR
4.2L XJR, S-Type R and XF SV8
The 4.0L XJR/XKR system looks very much the same as the 4.2L XKR, but the lower manifold is different as you see in your pics. Looks like you've got them mixed together.
The 4.2L XJR, S-Type R and XF SV8 is a totally different arrangement, not the one you want.
4.0L XJR and XKR
4.2L XKR
Sincerely,
David Piel
Newby
06-06-2012 12:18 AM
avos
05-28-2012 06:07 AM
