XJ8 the light bulb inside the high beam at the bottom
Old May 19, 2017 | 01:16 PM
wrd0225's Avatar
Default XJ8 the light bulb inside the high beam at the bottom
It is located in the high beam housing at the bottom. This small light is not working and needs to be replaced. How do I get it out? Do I pull it straight out or does it screw out. Where do I find the number or specification for it?
Old May 19, 2017 | 01:44 PM
avern1's Avatar
It is a wedge type 5watt bulb and though it is stiff it just pulls out by gripping the rubber holder.
Old May 19, 2017 | 02:16 PM
nilanium's Avatar
The whole connector twists and then pulls out, then the bulb is just a press fit
Old May 19, 2017 | 08:07 PM
motorcarman's Avatar
The lamp is called the 'PILOT LAMP' among other descriptions.
bob
Old May 20, 2017 | 03:54 AM
Daim's Avatar
Us Europeans call it a parking light...
