XJ8 lower ball joint removel
Old Apr 27, 2020 | 05:25 PM
Vinman's Avatar
Default XJ8 lower ball joint removel
Need help (procedure) for removing lower ball joint on my 1998 XJ8. I must be missing something, upper came lose easy. I'm also replacing front wheel bearings.l Thanks!
Old Apr 27, 2020 | 09:07 PM
nilanium's Avatar
Which part of the procedure are you stuck on?
Have you downloaded the X308 shop manual? It's got the procedure for R/I. http://www.mediafire.com/file/bu2w7j...anual.pdf/file
Lots of other files available here https://www.mediafire.com/?oc5ad7qbl2j6t#oc5ad7qbl2j6t and the advanced search (in the black bar near the top of the page) will bring up lots of threads if you search "ball joint" in the x308 subforum.
Vinman
Dec 31, 2019 12:08 PM
Vinman
Oct 26, 2019 07:57 PM
600HPCAD
Mar 23, 2015 08:34 PM
Twistedthread
May 21, 2012 11:32 PM
Morgai1
Oct 24, 2011 10:53 AM
