XJ8 Remote Programming
Old Mar 22, 2010 | 07:21 PM
Swick's Avatar
Default XJ8 Remote Programming
Hi guys. I have a 99 XJ8 with no remotes. I seen some on ebay which are advertised for my car for about $50 a piece. I called the dealership to ask for a part number so I can match them up, instead of giving me a part number I was told that I can't program them myself and have to bring the car in to them. They said it'll be $192 to purchase each remote and $140 to program each one. I explained that I have bought them myslef for other vehicles and programmed them myself, but they insist that I cannot do it. This is contrary to everything that I've read online so far, including ebay. Any input?
Old Mar 22, 2010 | 08:20 PM
test point's Avatar
Not true!
Ask another dealer to provide the part number from the VIN. Shop for the remote. Programming instructions are available here:
https://www.jaguarforums.com/forum/s...ad.php?t=10496
Old Mar 22, 2010 | 08:59 PM
Swick's Avatar
Thanks again Test Point, I will call another dealer tomorrow.
Old Mar 26, 2010 | 10:33 AM
Swick's Avatar
Just to follow up, I ordered two remotes from ebay, got them both today & programmed with no problem. Just as easy as programming went on my Chevy & Dodge. I had the seller put his instructions in the package with the remote and they were the exact instructions I found on here.
1. hold back high beams
2. Insert key and put in #1 position
3. flash high beams 4 times
4. Push button on one remote and then corresponding button on other remotes until done.
Its that easy. And I didn't even call another dealer, you can look up the part number online, look at the picture, make sure the seller is advertising the right one, and match it up with yours. Thanks again guys.
Old Mar 26, 2010 | 05:01 PM
newuser's Avatar
Default you can get cheaper remotes if you research
I suggest you do more research on ebay. Get the part number from the dealer by giving them your vin #. Then go on ebay and enter that part number on the search box. I was able to get a remote in excellent condition for $10. including shipping. Program it yourself as described above, it's really easy.
Old Mar 26, 2010 | 05:19 PM
newuser's Avatar
ooops, didn't' read this before my previous reply.
Old Apr 16, 2010 | 03:26 PM
diceman's Avatar
I just did this via the dealer. I bought the remote for my 2003 XJ8 on eBay for $30.
I paid the dealer $55 to program the remote. If you buy the remote from the dealer it's about $200!!
And God forbid you only need a key. That's $144.
Hilarious.
Anyway, I ordered a 2nd remote on eBay, and THIS TIME, I plan to try to program per the directions above.
Old Apr 16, 2010 | 03:27 PM
diceman's Avatar
Oh and btw, my dealer in Edison, NJ would NOT hand out part numbers.
Said it's against policy to provide that to 'customers'.
Old Apr 16, 2010 | 04:40 PM
test point's Avatar
Tell a manager it is against your personal policy to do business with them.
Old Jun 17, 2010 | 12:30 PM
alckc's Avatar
FYI for anyone with a 98 VDP who wants to program extra remotes. I followed the posted instructions; however, I had to have the drivers door and trunk open.
Old Mar 3, 2011 | 02:03 AM
SirJag's Avatar
Default No remote... what should I do?
Hi!
I, too, need a remote. I see many on Ebay.
But RE: your quote above, what happens if you don't already have a remote?
Thank you!
SirJag
Old Mar 3, 2011 | 04:42 AM
Sean B's Avatar
if you only have one, deliberate slowish pushing on a button I think 5 times. It'll then be programmed to the car. It'll let you know with the gear selector led flashing or a chirp.
Old Mar 4, 2011 | 04:53 AM
SirJag's Avatar
Thanks.
Has anyone else successfully programmed a remote when that's the only remote you had?
Old Mar 4, 2011 | 07:55 AM
Boomer from Boston's Avatar
Do a search on remotes in the forum. Might be under XK8. Anyway, the programming process is set up for up to 5 remotes. If you only have one, you are programming it to the car 5 times, which is why Sean B said to push the button 5 times. If you had 5 remotes, you'd push the button on each, once. If you had two remotes, you'd push the button on one of them three times, and on the other twice, for a total of five button pushes.
Old Mar 6, 2012 | 01:38 AM
psiharath1's Avatar
Default 2000 xj8l
I purchased the remotes for $10 and programmed it according to the instructions and it works like a magic. I've had my XJ8L for over 8 years and was told it would cost me hundreds to program and that only the dealer can program it. Glad I found a way around it. Cheers!!!
Looking to upgrade/modify. any suggestions would be wonderful. Recently installed a stubby antenna and will install 6K or 8K HID. Cant seem to get my headlights to be bright.
If anyone knows of any Jaguar Junk/Salvage yards in TX (DFW) please let me know.
Old Jul 22, 2012 | 09:15 AM
louisgar's Avatar
Hi I was checking out your postings. Man this site is great.
I have the same situation. I bought the car with no control.
I lent the car to a friend and she couldn't get in the car. She must have turned it really hard cause it has a lot of play and now i'm scared to lock the doors.
I bought a control on ebay but not by part number. I bought it by model and yr of the car. which is 98 xj8 . i went to the instructions you ask to use but it seems to be for xk series. do you have the instuctions for mine 98 xj 4.0 ?
Old Jul 22, 2012 | 09:35 AM
louisgar's Avatar
these programing instructions are for XK.
Can you supply programing instructions for (98) XJ8?
Please...
Old Jan 16, 2014 | 09:19 PM
RSpi's Avatar
My brother's remote does nothing for the car. Is there a way to test the remote or should I just try to program it?
Old Jan 18, 2014 | 10:06 PM
Zorasmiles's Avatar
Try reprogramming first and foremost. If it doesn't reprogram, time to dig into the remote. Considering you only have one remote, it makes it hard to trouble shoot. If your brother had two remotes it might be a little easier to trouble shoot. Good luck.
Old Feb 3, 2014 | 08:59 PM
RSpi's Avatar
Well, I tried to re-program the remote and it worked a couple of times. The trunk button seems to work all of the time, but the door buttons only work a time or two after I do the programming. :?
