XJ8 Stability Control Problem
Old Jun 2, 2008 | 07:04 PM
jag_genius's Avatar
Default RE: XJ8 Stability Control Problem
go and get the codes read.. if it says c1095 then it needs a module or get it rebuilt..
Old Jun 3, 2008 | 11:18 AM
Brake buster's Avatar
'99 XJ8 .................................................. ........., prime candidate for a new battery,
as an aging battery will throw spurious fault codes out leading you up the garden path,
unless you know its a new battery and its good, it a good cheap alternative to chasing ghost problems , though you should still get things checked out properly
hope this helps
BB
Old Jun 3, 2008 | 09:11 PM
ibjags's Avatar
week battery will usually just make the trac not available flash on momentarily when car first started
then goes away and usually doesnt present a fault afterwards
that is until next engine start
first thing first get the code read and then let us know what you have for a code
Old Jun 5, 2008 | 09:22 AM
ken@britishparts.com's Avatar
Very possible. Most plug in scanners read the emission codes only.
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
jdzubas
Oct 4, 2015 09:14 AM
mcdutch
Sep 4, 2015 03:38 AM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
