XJ8 throttle body guidance
Old Nov 10, 2022 | 04:57 AM
Fulhamsteve's Avatar
Default XJ8 throttle body guidance
Hello all,
I've been lurking this forum for a while but finally gotten around to creating an account. I am the owner of a 1998 4.0 XJ8 sovereign. It has had a number of issues for a little while which I am trying to work through.
I have pulled off the throttle body (lcc1560aa) and found that there is a rubber vacuum line which is just cut off and doing nothing underneath. It is below and behind the TPS, pointed downwards. On the image below, it is the small pipe on the far left, diagonal down from the bottom left of the green gasket and to the left of the coolant line.
Where should this be attached to? What should this look like? No diagrams seem to have a good angle to show it.
Old Nov 10, 2022 | 08:42 AM
M. Stojanovic's Avatar
Nothing connects there, it's just a drain pipe for any condensation inside.
Julia700
Nov 5, 2022 02:38 AM
Terry007
Sep 7, 2021 05:33 AM
Phil m
Aug 25, 2021 10:36 AM
semorex
Jun 12, 2020 08:47 AM
MarkyUK
Aug 23, 2019 10:39 PM
