xj8/ xjr engine differences?
Old Jul 3, 2009 | 01:04 AM
avos's Avatar
What is the plan?
Old Jul 4, 2009 | 01:44 AM
wazari's Avatar
Different pistons and valvetrain. The bottom end on these motors are very robust even though they are cast pieces. Very high quality castings.
Old Jul 4, 2009 | 03:39 AM
avos's Avatar
If indeed the plan is to use parts of an R engine to strengthen the 8 engine, then it is indeed as wazari says. Stronger wouldn't make sense either if you stick to the stock hp, then it would be better to think about a 4.2 block.
Old Jul 4, 2009 | 05:28 AM
sparkenzap's Avatar
Default ?? for Avos
I did not uderstand your post- Are you implying there are other changes besides pistons & valves in the block assembly?
Old Jul 4, 2009 | 04:41 PM
wazari's Avatar
The normally aspirated motor has VVT.
Old Jul 4, 2009 | 06:04 PM
JagtechOhio's Avatar
jag_genius encountered the difference between N/A and S/C blocks, but I think it was only concerning the blower mounting points. Check out his posts from about 6 months ago. He built an S/C motor on an N/A block, and had to fabricate an adapter plate for the blower.
As for the bottom end, I thought that the only other difference was the piston crowns.
Old Jul 4, 2009 | 09:13 PM
wazari's Avatar
yup, that's it.
SD96XJ6L
Jan 12, 2022 04:30 AM
jehart49
Sep 12, 2015 05:36 PM
tberg
Sep 7, 2015 07:32 AM
AlbBolivar
Sep 1, 2015 04:34 PM
Andrew McVey
16
Aug 27, 2015 07:21 PM
