XJR = Not a Snow Car
Old Jan 20, 2011 | 11:01 AM
amcdonal86's Avatar
Originally Posted by benebob
Look at his location. They get below freezing what 10 times a year?
Haha, Atlanta isn't as tropical as you might think!
http://www.wunderground.com/NORMS/Di...=none&IATA=ATL
Even under 50 degrees, the performance of summer tires is severely diminished.
Old Jan 20, 2011 | 12:23 PM
benebob's Avatar
ud
Ah but the performance at 50 degrees for summer tires by far exceeds that of snows in non-snow conditions. Even at 20 degrees the day I changed over to my winter wheels I lost a solid 20 feet in dry braking compared to my nearly corded summer tires.
Old Feb 8, 2011 | 10:11 AM
john_stafford's Avatar
Default Put weight in the trunk
In Ireland we don't have too much call for snow tyres (most years go by with no snow at all). However, when there is snow, it is highly effective to put a couple of sacks of sand in the trunk; this increases traction for the rear wheels. It really makes a difference.
Old Feb 9, 2011 | 08:05 AM
Viapa's Avatar
Originally Posted by squish
Like I said, the ramp looked dry. I currently have summer tires. This snow/ice in Atlanta has been pretty bad. I guess my title should have been "XJR + Sumer Tires = Not good Snow Car."
I live in Atlanta. I also own a 03 XJR R1. I have some Mina Gallery sport mufflers for sale. I'm asking $250 for mufflers if you are interested. They are in excellent shape. Go to www.minagallery.com to see what they look like. Contact me at via_pa@yahoo.com if you have any other questions.
Old Feb 9, 2011 | 08:08 AM
majbill's Avatar
Default Not a Snow Car
Of course nothing helps on ice-even iffy with chains. I just totaled an 02 VDP in January. Ice I did not could not see until I was on it at night. Roads were clear for miles but apparently this slight downhill is in the shade so didn't melt off. Just recently replaced the 02 with a very nice low mileage 04 XJ8. Even with snow tires on any of my cars I have always put some weight over the rear tires in the trunk. Like our Irish friend says it helps. Also if you were to become stuck you can always break open the sand bag(s) and put the sand under and around your tire(s) and drive out. Not a bad idea with the even with the best of snow tires on your car. Also not a bad idea to carry a small collapsible shovel in the trunk.
Another thing...I don't drive the Jag in the snow. I drive my truck now. Just happened on that particular night I could not drive the Titan as it was out of town with my wife. Biggest hurt was my feelings....I had not control solid ice for about 200 feet in both lanes. It was what I call one of thos Aw Sh-t moments where all you can do is hold on for the ride.
Bill
Old Feb 9, 2011 | 03:27 PM
X308_XJR's Avatar
I'm in northern Indiana, 7 miles from the Michigan line, and we get lots of snow. I put Dunlop winter sport tires on my 99 XJR and have had no problems. Of course, I drive sensibly in poor conditions.
The OP obviously was not expecting ice or he wouldn't have punched the throttle (I hope). Releasing the throttle in the middle of a curve will also give you nasty lift in the rear end and possibly put you out of control. Moral - be aware of weather conditions and always try to anticipate the unexpected.
Old Feb 9, 2011 | 08:38 PM
vdpnyc's Avatar
Mine has seen limited snow driving, but it seems to not get stuck or free-spin in snowed over parking spots (and my previous RWD car did all the time)
Old Feb 11, 2011 | 02:22 PM
  #28
Husker4's Avatar
Default My XJR does fine in Minneapolis in the winter.
I have a good set of snow wheels/ tires and my XJR does great in the winter. I did just have my ABS module rebuilt, and it was hell without traction control in the snow for a bit..
Old Feb 13, 2011 | 03:09 PM
Ipc838's Avatar
What I thought of doing (should I end up going to a university in the north) is going on CL, and buying an old set of 16" wheels from an XJ6 or Vanden Plas, and then just putting those wheels on it for the winter (snow tyres for my 18"s are insane, they don't even seem to make them!--Too spensive) So I could have a set of winter wheels with no worries about curbing the hige wheels it has, and in the winter have better traction (and more fun on summer tyres).
Old Feb 13, 2011 | 04:05 PM
  #30
Husker4's Avatar
Default 18's
Not sure if you have a XJR or XJ8, but if you have an XJR, you will not be able to go smaller than 18" because of the size of the front brakes (non-brembo)..
I was disappointed to find this out as in the past I have usually gone done a size or two for winter wheels and tires..
Old Feb 13, 2011 | 07:56 PM
  #31
benebob's Avatar
ud
About $8-900 for a decent set but they would last you all 4-5 years if you run 'em from Dec-March. That's what the cost of a week of school.
Old Feb 13, 2011 | 09:41 PM
  #32
MidlifeXJR's Avatar
As others have told you, your brakes won't fit with the smaller wheels. For the price of wheels for this car, you might just want to look at mounting and unmounting a good set of snow tires, or for the price of the insanely priced tires, just buy a beater car and drive it during the winter!
Of course, you could just pick a university in the south from your neck of the woods to So. Cal. and generally that should take care of it. I think Arizona and So. Cal. are the only sunbelt areas other than Southern Florida that didn't get snow this year!
BTW, great looking car you have there if I do say so myself!
Old Feb 14, 2011 | 10:18 AM
  #33
SteveM's Avatar
His signature says XJ8 Sport. Don't know if they have the bigger XJR brakes up front. Anyway, I'm sure you can fit 17" on the front of the XJR and 16" on the rear.
Old Feb 14, 2011 | 10:36 AM
  #34
vincent661983's Avatar
XJR is totally NOT a snow car. every winter,I have hard time to just pull up my car to my driveway from street just the little ramp if I have an inch snow on the ground.
I spined 360 on NJ turnpike once on a snow day
this winter is even worse
Old Feb 14, 2011 | 05:01 PM
  #35
SteveM's Avatar
It has very little to do with the car, and everything to do with the tires. Sure, with the P-zeros or other summer tire then it's pretty much impossible even in light snow.
With snow tires, my winter XJR was a tank in deep snow, never got stock and lots of fun.
Old Feb 14, 2011 | 08:58 PM
  #36
johnleavitt's Avatar
Snow?
Old Feb 15, 2011 | 03:34 PM
  #37
Ipc838's Avatar
The 16"s will fit on my car, its has got large brakes but I'm confident they are the same as the XJ8's brakes, so 16" will fit ok. And I found a nice set on orlando CL for like 200$. and those were on decent goodyear all-seasons (well, no such thing, but ok tread) and were from a Vanden Plas. Plus, in addition to them being narrower (ergo, better in snow) They are also not going to get curbed in an icy parking lot. And I'm fairly sure my brakes are XJ8 brakes, but they seem very large-maybe the sport got a brake upgrade. Oh and nice car yourself, MidlifeXJR-good choice of wheels and colour lol
Old Feb 16, 2011 | 12:25 AM
  #38
tylerh860's Avatar
The "beater" is my 1991 Sierra Ext. Cab Z71 with the 6.2 diesel with an old coach conversion leather bucket conversion. Even with a foot of snow on the ground I rarely have to use the 4x4. The biggest benefit is it keeps the salt off my good cars. I HATE road salt.
I named it Chuck Norris.
Old Feb 16, 2011 | 12:46 AM
  #39
Superduty65's Avatar
"What's all this snow stuff y'all are talking about?"
Lock it up Florida boy!
Old Feb 23, 2011 | 02:32 PM
  #40
lokuputha's Avatar
The two issues with the XJR chassis are the extra-wide tires and the relatively non-compliant suspension system; both of these issues tends to give incredible dry grip but the chassis rarely hunts for traction.
I have 245/50-17 Dunlop winter tires on 17" XK8 wheels on my XJR and they are still too wide to cut through any amount of Canadian winter deeper than 3".
Solutions: maybe get even narrower tires with very deep tread. Tirerack recommends 225/55-17... SP Winter Sport 3D should do the trick next winter.
