XJR -98 Headlights turning off in "auto-mode"
Old Mar 27, 2011 | 04:41 PM
Mr_Dobermann's Avatar
Default XJR -98 Headlights turning off in "auto-mode"
Hi all,
I have a XJR -98. Im currently working with this car, and i have a issue with the headlights.
When the light stalk/switch is in "Auto-mode/position" and i start the car up, the lights are on for maybe 20 sek - 1 min, then they shut off. Then i need to put the stalk/switch in the next position, the manual "on" mode to get the lights on again. Does anyone recognise this problem? Can it be a relay to the Headlights or is the problem located behind the steering wheel column, near the light-stalk/switch?
Thankful for help here.
Kind regards, Kimmo/Sweden
Old Mar 27, 2011 | 04:53 PM
QuadManiac's Avatar
Obviously, it is dark when this is happening? Is there anything in front of the car that could be reflecting light back to the sensor?
Old Mar 28, 2011 | 06:30 AM
It doesnt matter if it is dark or daylight, or rain or sunshine... The car does this all the time.
Strange behaviour.
Kimmo/Sweden.
Old Mar 28, 2011 | 02:59 PM
chupacabra's Avatar
are you sure it was dark when you tried it??
Old Mar 28, 2011 | 04:01 PM
Sean B's Avatar
I've not experienced this, but the sensor is something you might look at cleaning first - this is on the rear view mirror facing the windscreen. A Q-tip with a small amount of glass cleaner will work.
Old Mar 28, 2011 | 06:31 PM
dba-one's Avatar
99xk8guy
May 28, 2024 09:36 PM
avern1
Sep 6, 2015 04:22 PM
sklimii
Sep 5, 2015 06:04 AM
laserguy
Sep 3, 2015 02:02 PM
King Charles
Sep 3, 2015 12:40 AM
