XJR changed battery and stereo stopped working???
Old Apr 11, 2010 | 04:38 PM
xjr4life's Avatar
Default XJR changed battery and stereo stopped working???
hi everyone,
can anyone tell me why after changing the battery the stereo has stopped working???
where is the fuse for the stereo located?
also does anyone know how to set the memory of the steering wheel and seat to auto position when inserting the key in ignition and taking out of the ignition?
does the memory buttons 1,2 and 3 having to correspond with the individual key fob?
regards
Old Apr 11, 2010 | 08:05 PM
QuadManiac's Avatar
Does the stereo display (what year XJR, please) ENTER CODE, or equivalent? Some Jag stereos require an anti-theft code when they've been deprived of power. You can call your local dealer's service department, give then the last 4 or 6 (don't remember) numbers of your VIN and they will give you the code. The fuse is also a function of year.
The steering wheel memory uses a twist switch on the left side of the column (at least in my 2000) - OFF for manual, AUTO for auto adjust when the key is inserted. In auto, the wheel will return, upon key insertion, to the last postion prior to removing the key. The seat memory is linked to the key fob that you use to open the door - push mem 1, then press a button on the keyfob - you'll hear a ding; that key fob is now associated with mem 1. Same process for mem 2 and 3.
Old Apr 11, 2010 | 08:40 PM
xjr4life's Avatar
hi thanks for reply its a 2000 model xjr, no display comes on at all the buttons illuminate green but when u press the on/off/volume knob no power no display...
where is the fuse located? rough ideas on the location?
thanks for your help again
regards
Old Apr 11, 2010 | 09:13 PM
QuadManiac's Avatar
regards
Fuse for the head unit is Fuse #9 in the left hand heelboard fuse box (under the left front edge of the rear seat)
Old Apr 16, 2010 | 06:55 AM
xjr4life's Avatar
thanks mate for your advice, all problems sorted....
fuses were ok, turned out i didnt let the car reset connected the new battery too quick so i took the neg cable off and let it sit for 5 mins then reconnected and code came up punched in code and all is well
thanks again mch appreciated
regards
Old Jul 29, 2010 | 08:45 PM
pdog2000's Avatar
just curious...what type of battery did you replace it with
kurtomatic
Feb 12, 2024 06:58 AM
Drew2006
Nov 24, 2015 11:14 AM
johnnie ryall
Oct 19, 2015 09:44 PM
Jandreu
Aug 29, 2015 07:31 PM
