xjr diff mangled
Old Sep 12, 2011 | 02:20 PM
driver safz's Avatar
Default xjr diff mangled
hey all, my xjr diff has been mangled up, it siezed up letting the wheels run free twisted and snapped the propshaft :/, will the 4.0 standard xj diff fit it?
Old Sep 12, 2011 | 03:56 PM
Stu 1986's Avatar
Yes it will, and I have one with 107,000 miles on I'll sell you if you like. I also have a propshaft but will have to get back to you on whether the 4.0's fits the XJR. I'm in Liverpool.
Stu.
Old Sep 12, 2011 | 03:58 PM
Sean B's Avatar
So this was your vibration? Yes all diffs x308 fit.
Old Sep 12, 2011 | 05:35 PM
thank god lol, i have an xjr propshaft mate just dont have the diff, howmuch will the diff be for me?
yeah i think that was the vibration
Old Sep 17, 2011 | 05:04 PM
johnleavitt's Avatar
I got a diff delivered in the usa for 270usd, and a propshaft for 190 usd. Eat your wheaties before you do the job. The bolts are big and tight and the parts are heavy. As for the any diff issue, there are really two different ratios, a 3.08 and a 3.27. While I am sure both will work, I made sure I got the correct one, which was a 3.08 on my 2003 xjr r1, because I was worried about a gear fault putting the ecu into limp home mode if the wheels were not spinning at the speed the ecu thought they should. Maybe somebody else knows if it makes a difference to the ecu, but I played it safe. I would have rather had the 3.27, but settled for what it came with.
Old Sep 17, 2011 | 05:25 PM
Jaxkr's Avatar
The only application for the 3.27 ratio diff is for the Mexican market. They use it in non supercharged cars (something about fuel quality effecting performance). I have a TCM for a supercharged car programmed for 3.27 ratio, it was in my car for a short time.
vwbusbits
Oct 13, 2015 03:43 AM
xjrjag
Oct 12, 2015 03:16 PM
Tipptone
UK & Eire
Oct 1, 2015 10:50 AM
JAMES1944
Sep 29, 2015 11:58 AM
moff1959
Sep 26, 2015 05:35 PM
