XJR fuel injector specs?
Old Apr 22, 2012 | 02:47 PM
JKo's Avatar
JKo
Is it possible to remove the injectors without taking the charge coolers off? Haven't tried yet, but it looks pretty cramped there...
Old May 11, 2012 | 08:07 AM
JKo's Avatar
JKo
I guess no-one has ever removed the injectors from a supercharged engine.
I got the E85 piggyback system, but the gap between the valve cover and the cooler is too tight even for the injector connectors to come through... I'm planning to have the tensioners and chains replaced soon anyway (and perhaps upgrade the lower pulley too), so I was thinking about having the injectors replaced with bigger ones on the same go...
Does anyone know if those 550cc injectors are available anywhere in Europe? I guess Buckhead can ship them over, but I'd rather avoid paying the extra taxes.
Avos, are those 4.2 injectors a direct fit?
Old May 11, 2012 | 08:49 AM
avos's Avatar
No, you need the fuel rail/manifold from a 4.2 engine as well.
Old May 16, 2012 | 12:44 AM
JKo's Avatar
JKo
Import tax for the injector kit that Buckhead is selling would be almost 300€...
Is the fuel pressure regulator adjustable on these cars?
Old May 16, 2012 | 03:55 AM
avos's Avatar
The stock one isn't adjustable, I am using the Tomei FPR L version, am pretty pleased with it so far.
Old Aug 28, 2012 | 04:07 AM
JKo's Avatar
JKo
Originally Posted by JgaXkr
I purchased the 550 injectors thru Buckhead. If you call speak with Tony he is the person I dealt with.
Do the 550cc injectors require ECU tuning, or is the 20% fuel trim that the ECU can handle without throwing a code enough for them?
Price of regular gas is on the rise again here, and it's getting easier and easier to justify the cost of bigger injectors...
Old Jul 20, 2014 | 11:39 PM
FinJag's Avatar
There is an adjustable E85 conversion kit that allows you to do just that. It also has a few presets, so you can change between fuels by pressing a button if needed.
Bioadapter E85 conversion kit
Hello, what is the situation now with your project? In where do You operate in Finland?
Old Jul 22, 2014 | 12:12 AM
  #28
XJR-99's Avatar
JKo sold his XJR late 2012.
dsnyder586
Dec 29, 2024 07:39 PM
Charlene n John
Sep 28, 2015 06:01 AM
Bcrary3
Sep 11, 2015 10:36 AM
al_roethlisberger
Sep 7, 2015 10:53 PM
Charlene n John
Sep 6, 2015 11:03 AM
